stacking help
Posted: Thu Feb 05, 2009 6:42 pm
by blackjack6969
:twisted: Im new at this I would like to stack the banks bullet and predator what seting do i use . Is their a stack seting that is not the 200hp one . I think that is to much for me right now .
Posted: Fri Feb 06, 2009 8:46 am
by kw5.9
not familiar with banks products the predator uses timing and durations so if the bullet does the same you will have a problem depending on what yr ur truck is y should have 4 stacking options stack the predator with a pressure box like the puck or extreme power puck.
good luck
Posted: Sun Feb 08, 2009 12:56 am
by ModManiac
I would only use a pressure box such as the puck or mp8 with it.
Posted: Sat May 22, 2010 8:42 pm
by 5point9
This has proven to be a good monster stack for me! The bullet can defuel it's part when egt's get too hot. With the predator alone, I don't see more than 1400deg. So I can crank the bullet, let it do it's thing, and if egt's get too hot (which they will with a predator/pressure box stack), the bullet will defuel! Works awesome, can't wait to hit the track!
