04 SRT Lots of knock with 93 tune
Posted: Fri Feb 06, 2009 1:53 am
by 04eblue
My knock reached 8 on the 93 tune with 94octane in the car.
I have Stage 2 w/o toys, Kinetics WGA set to 20psi and holding 18psi. Temperature outside was around 40F. I wasn't exactly at WOT but definately near 90%.
Just wonder if this might be normal with the Stage 2 owners with the 93 tune?
RE: 04 SRT Lots of knock with 93 tune
Posted: Fri Feb 06, 2009 12:46 pm
by dongalonga
Why weren't you WOT
Posted: Mon Feb 09, 2009 9:59 am
by Letxen3
are you on PCM controled boost with your kinetics wga? can you post a log also? FYI....the 93 tune is for the stock wga unless you have your wga duty cycle scaled down for your kinetics wga.
Posted: Mon Feb 09, 2009 11:47 pm
by 04eblue
The WGA is hooked up identical to the stock WGA. I do plan on turning the boost down tonight though since as soon as i hit 3200RPM+ at WOT the tires start spinning in second or third gear.
I will turn the boost down a couple PSI and then do a log just to compare.
Worst case scenario i will be getting a tune done at a local CMR dealer since they only charge about $200/hour. $150/hr for the dyno and $50/hr for the tech to tune it.
