Need Updates for a tuned 7.3TD
Hi guys!
I have a 2001mod 7.3TD upgraded now with Bankspower power elbow, 4" exhaust and a GTP38R turbo!
Does anyone here a upgrade that fits this setting? im using the U7170 or what its called..
RE: Need Updates for a tuned 7.3TD
Got some specs for this turbo?
Insert Clever comment here...
or how can i remap my engine using the predator... i need the auth.code
the gtp38?.... Its the most known upgrade for the 7.3 engine... not sure the specs
did you find out something?!
Use the 100hp tune.
ok, and youre totaly sure about this?.. how many PSI does it load on that tune?.. i still have the 9.03r chrome.. ?
30psi.
Hm.. im allready running 30PSI on the 85HP set up!
Youre sure that my engine will feed enough fuel for this setup with the GTP3880R turbo?
One more thing, MIKE sent me once a costum file.
http://sperra.no/file/vraa7y6_rdlx3m_highpress.frg
Can you tell me something about this file?
do i need to update my predator? what are the changes since 9.03r
Nothing for you to be concerned with it was for a calid that had a problem not being supported... As for your truck being able to support it I cannot answer that as I have not personally tested with one of those... Watch you EGTs.
ok. what is the limit of the egt?
Depends on where the probe is. If it's on the downpipe 1200 if it's on the manifold 1375-1400
hhehe ok. not even close.. holdeing stady 800 MAX 900degree on extreme setup!
But it doesnt make so much black smoke anymore.. is that good? with the original turbo it smoked like H#¤%&/!!
now its moderate:) better for the pedestrians;) ahha!
