Chanching gears thru Predator
venomsvt
Post by venomsvt »
ok i recently swapped my irs out for a sra and it came with 373s, and i previously had 355s when my car was tuned, do i need to change this on the predator or it doesnt matter? and if i do need to change it can i do it myself and how? by the way the car is a 03 cobra, thanks alot, any help would be appreciated
kottonmouthkings69
RE: Chanching gears thru Predator
Post by kottonmouthkings69 »
as far as i know you just go into modify tune selrct axle and then select the gear your using
Phil
Post by Phil »
Go to modify tune/modify parameters/Axle ratio .... And make the gear change there.
Phil Jones
Diablosport Inc.
Tech Support
Please do not PM us for tech support, post up first!!!
Return to “Predator Ford Gas”
