Page 1 of 2
Steeda CAI & U7145 DiabloSport Predator
Posted: Mon Feb 16, 2009 1:27 am
by amm
Which is better to fix the CAI and then installing the Steeda 91 Octane Performance tune .. Or the reverse.
Your help will be appreciated and thanks a lot!
RE: Steeda CAI & U7145 DiabloSport Predator
Posted: Mon Feb 16, 2009 8:11 am
by lito
either way is ok as long as you don't start the car in the mean time (it won't do any real harm just that it won't work well).
Posted: Mon Feb 16, 2009 1:10 pm
by amm
what is your recommendation .. and do I need to disconnect the battery ??
Posted: Mon Feb 16, 2009 1:47 pm
by lito
Is a safety measure you could take for every job in the car, do it while you change the MAF if you want but it really won't hurt if you don't.
Posted: Mon Feb 16, 2009 5:26 pm
by amm
About the expected HP I'll get 35 HP for the wheel or the engine ?
Posted: Tue Feb 17, 2009 7:49 am
by amm
Posted: Tue Feb 17, 2009 7:54 am
by lito
They are at the engine, reality check is that you won't pick that much, nobody does, but nobody should care about that anymore.
You've got one of the nicest CAI available and you will love your car once tuned.
Posted: Tue Feb 17, 2009 1:50 pm
by amm
After fixing the steeda CAI and Tuning the car (Steeda 91 performance tune) .. I have many errors one of them is
(!) that appearing all the time .. Also the computer said that the tire pressure is low and there is no enough fuel .....
Please I need some help
After clearing codes and driving it again (5 minutes) then the check engine light is on all the time .. I check for trouble codes and thats what I found:
- P0605
- P1000
Please I need some helps as soon as possible and thanks a lot.
Posted: Tue Feb 17, 2009 3:01 pm
by kmac1
Could you please include the following: Calibration ID of the vehicle, revision # in the Predator and the name of the tune that you installed.
Kevin@Diablo
Posted: Tue Feb 17, 2009 3:31 pm
by amm
Upgrades: Steeda high velocity CAI with the stock factory tube and the U7145 Predator.
Tune: Steeda 91 Octane performance tune.
I have check engine light trun on and the trouble codes are : p0605 and p1000
Thanks for your help .. and I'll go to check the Calibration ID and Revision now ..
Posted: Tue Feb 17, 2009 3:47 pm
by amm
Version: V.9R02
CALID: FOAN0G4HEX
Tune: 91 Octane Steeda
Serial: d00b47b
Upgrades: STEEDA high velocity CAI with stock factory tube and U7145
Problem: First the (!) appear then after clearing codes disappear and the check engine light turn on
Trouble codes: p0605 and p1000
Please I need some helps and thanks a lot ...
Posted: Tue Feb 17, 2009 6:25 pm
by kmac1
amm, you need to update your Predator. This was fixed in the 9r03 revision...
Kevin@Diablo
Posted: Wed Feb 18, 2009 2:44 am
by amm
Ok .. there were three tunes for Steeda CAI
85mm,
90mm and
Steeda 91 Octane .. So I'm confused between them .. I choose the 91 Steeda performance tune .. am I in the right way ??
I'll Update my Predator and then see what will happen ...
Thany you very much
Posted: Wed Feb 18, 2009 7:27 am
by amm
I update it to the last version
9r03 .. and I'm waiting your answer about the tune to choose and will match my system (Steeda high velocity with the
stock factory elbow tube) ..
- 85 mm Steeda tune
- 90 mm Steeda tune
- Steeda 91 Octane tune.
Note: I hope that the attached image will help you to answer my question.
Thank you very much
Posted: Wed Feb 18, 2009 11:21 am
by amm
