Page 1 of 3
Analog inputs - more info
Posted: Tue Feb 17, 2009 2:59 pm
by parsonsproject
u7134
v.9t75
2004 dodge neon srt-4
I checked the PDF manual and did some searches but couldn't come up with much.
I've got an aem wideband with a 0-5v analog output. Is the only way or the best way to connect it through the mini headphone jack?
What are the analog input channels under options? Channel 1, channel 2, battery voltage, peak to peak voltage, trinity temperature? Which would be used for that mini headphone jack?
What should lower and upper bounds be set to for the AEM UEGO?
RE: Analog inputs - Need more info
Posted: Tue Feb 17, 2009 4:01 pm
by johnc
The updated manual should be coming along soon. You need a 2.5 mm stereo plug, which is DigiKey part # CP-2501SP-ND. Wire it up as follows:
To convert the slope/intercept, try the following:
low value = intercept
high value = intercept + ( 5 * slope )
I am going to sticky this thread for others.
Posted: Tue Feb 17, 2009 6:11 pm
by wetcoast
For Innovate I used low 0V input of 7.35AFR and high 5V input of 22.39AFR. It seems to be working well so far but I haven't verified it against Logworks yet.
Posted: Tue Feb 17, 2009 7:46 pm
by wetcoast
I just recorded a log in the car and downloaded it to DS Dataviewer. Analog input reports back scaled properly and looks to be really accurate compared to the Innovate Logworks. I'm all smiles! This is fun again!
I have some rough tuning to do now.
Posted: Tue Feb 17, 2009 8:02 pm
by sfla_srt4
damn I wish I could get mine to work.... wetcoast, what plug did you use?? Im having issues here
Posted: Tue Feb 17, 2009 8:04 pm
by wetcoast
I had a 2.5mm jumper from my innovate LC-1 kit. I hacked it off and soldered a shielded cable to it and plugged 'er into the Trinity. I'm using analog input #2 per John's diagram.
Get one of these.
http://search.digikey.com/scripts/DkSea ... CP-2204-ND
Mine's on the way
Posted: Tue Feb 17, 2009 8:08 pm
by sfla_srt4
well I have some old headphones that were broken so I took the cable off. It looks exactly like your pic but I have it just "temporarly" wired into the trinity.. I have the 0-5V wire from the eugo going to wire off the headphone jack and then the jack into the trinity.. Im having a problem with the monitoring screen freezing though.. I made a post about that though, but wanna know how to wire up the actual unit.
Posted: Tue Feb 17, 2009 8:14 pm
by wetcoast
Use an ohm meter!
Find the lead that is connected to the base portion of the 2.5mm jack. That will connect to the Eugo ground. Then connect one of the other leads to the Eugo 0-5V wire.
Go into the options menu. Configure both analog inputs for the intercepts you've calculated (or use mine above if you have an Innovate).
Go to the logging menu. Configure your own gauge page. add the analog inputs as a gauge.
Then go to the monitoring page.
Posted: Tue Feb 17, 2009 8:27 pm
by sfla_srt4
I am doing that.. The jack is getting voltage from the WB and everything is hooked up. I make the new page on my layout and add the "WB" Pid that I made. I then go into monitoring and click my layout. The screen should normally show "Live Data" and show the loading bar, but it does not. Instead, it will go directly to the layout page with all of my gauges on it and freeze.. I cant cick anything, touch the screen etc.. I have to uplug the unit and do it over. I keep getting the same error. I tried go into the default layouts with none of my additions of the analog inputs and the monitoring works fine.. Ver wierd to me know.. Also, same error happens in logging section
Posted: Tue Feb 17, 2009 8:29 pm
by wetcoast
Sounds like the SRT-4 crom needs some tweaks.
Posted: Tue Feb 17, 2009 8:31 pm
by sfla_srt4
I hope not lol I want this!!!
Re: RE: Analog inputs - Need more info
Posted: Tue Feb 17, 2009 8:41 pm
by sfla_srt4
wetcoast wrote:Use an ohm meter!
which part is the base, the lower portion or the tip??
RE: Re: RE: Analog inputs - Need more info
Posted: Tue Feb 17, 2009 9:14 pm
by wetcoast
Lower portion. The tip and the middle of the jack are the two input channels.
Posted: Tue Feb 17, 2009 9:17 pm
by sfla_srt4
check my newest thread.. Thanks for the help!!
Posted: Thu Feb 26, 2009 12:28 am
by sfla_srt4
I now have the input working but the calibration seems off.. I have the UEGO and the lower bound is set to "10.000" and the upper is "20.020". When the WB is steady the trinity is jumping around to random numbers. Like on idle, the afr on the WB will be from 14.7-14.8 and the trinity will throw a 15.6 up and then come back down to 14.5 and then another number.
What are you guys using for calibration numbers??
Also, on Dataviewer, I am not able to see the WB pid when I open the tune and view it.. Will this be enabled or what?
