Page 1 of 3
help srt-4 has a problem
Posted: Tue Feb 17, 2009 6:31 pm
by streetsteve
i got a diablosport, 3 inch side exit and hks ssqv and a fm wastegate actuator, if i hold like 17-18 psi for more than 5 seconds like in 4th or 5th gear it pulls strong then when i let off and get on it again i only get 12 psi until i hit 4000rpm then it will go up to 15 psi, if i turn my key off and restart the car it's fine until i hold boost for more than a few seconds, forward motion thinks it's my waste gate duty cycle, anything i can try to fix this. oh yea car is a 2005
RE: help srt-4 has a problem
Posted: Wed Feb 18, 2009 1:00 am
by chrisgst99
u check for any boost leaks?
Posted: Wed Feb 18, 2009 1:14 am
by sfla_srt4
are you running the included 93 perf tune?? Then yes, the WGDC% will be off. They are scaled for the stock WGA and not the stiffer FM WGA..
Posted: Wed Feb 18, 2009 2:13 am
by streetsteve
i'm going to check for boost leaks in the morning, yes i am using 93 octane, could i just have shit gas and it's knocking and pulling boost? 2nd and 3rd gear are right at 17 psi but 4th and 5th almost hit 20psi
Posted: Wed Feb 18, 2009 2:22 am
by sfla_srt4
is it knocking??
Re: RE: help srt-4 has a problem
Posted: Wed Feb 18, 2009 9:46 am
by sohfast94
streetsteve wrote:i'm going to check for boost leaks in the morning, yes i am using 93 octane, could i just have shit gas and it's knocking and pulling boost? 2nd and 3rd gear are right at 17 psi but 4th and 5th almost hit 20psi
there could be a multitude of things going on. I would have to see a datalog. As for the boost levels that doesn't sound bad.
RE: Re: RE: help srt-4 has a problem
Posted: Thu Feb 19, 2009 3:03 am
by streetsteve
what parameters do i watch for knock tot knock ret? tell me what parameters to datalog and i'll send them to you
Posted: Thu Feb 19, 2009 9:09 am
by sfla_srt4
knock ST, knock LT, RPM, MPH... check out this thread..
http://www.srtforums.com/forums/f384/wh ... og-484265/
Posted: Fri Feb 20, 2009 3:21 am
by streetsteve
ok i ran it again tonight and it didn't do it, but i still datalogged, this was the first time in 2 weeks it didn't do it, it was also the only time that was late at night, maybe temp has something to do with it, let me know what you think about the data log, thanks
the log has a couple of wide open throttle runs
Posted: Fri Feb 20, 2009 11:23 am
by sohfast94
Yeah you definitely got a problem alright. It's not the programmer though. Post you last tune wirtten.
Posted: Fri Feb 20, 2009 12:38 pm
by streetsteve
here is the last tune written, what was the problem?
i'm not sure why the tune says custom, all thats modified is when the fans come on because i got a 180 thermostat
heres a list of my mods
aem short ram
predator of course
maxxfab 3 inch side exit no cat with a resonator
3 inch o2 housing
180 thermostat
race motormount inserts
Posted: Fri Feb 20, 2009 2:15 pm
by streetsteve
is it something i can fix by changing the parameters?
Posted: Fri Feb 20, 2009 4:13 pm
by streetsteve
hey brian can you give me some info as to what my problem is thanks
Posted: Fri Feb 20, 2009 4:37 pm
by sfla_srt4
It may need to have the WGDC tables set for the FM WGA.. Give him some time, im sure he will get back to ya!
Posted: Fri Feb 20, 2009 4:48 pm
by streetsteve
it's not boosting too high i even turned the boost down to 15 psi with the wastegate and still did it.
