9r07
duramaxslayer
9r07
Post by duramaxslayer »
FYI
100 hp tune not boosting over 20 psi WOT, but still has plently of power
Egt's are not even hitting 1100 psi WOT
Shifts are rough when the trans is cold
Makes a lot more power then Juice Platinum and still shifts better
2004 F250 6.0 PSD
U7165
Cal id: VXBC9NA
9r07 crom
Question is: Should 100 hp tune hit more then 20 psi? :?:
sohfast94
RE: 9r07
Post by sohfast94 »
I don't raise the boost very much because of the EGR cooler and the weak head bolts. I could, but I don't for production tunes for that reason.
Insert Clever comment here...
duramaxslayer
RE: 9r07
Thanks for the quick explanation,Brian.
I am very happy with the unit.
I stack it with the Juice Platinum with Attitude to make some real power.
