'98 Camaro PCM? Which programmer do I need.
Can anyone tell me which DS I need? Pcm is from '98 Camaro, Painless harness is for '98 LS1, Motor is an '04 ZO6. The harness and computer are not ZO6 because the cable (non dbw) throttle body is being used. I had wait4me program the computer for the difference in pin assignments from '98 to '04. I currently have a brand new u7193 but it reads "unsupported vehicle" when plugged in. The original VIN is still in the Pcm. Please help with any suggestions.
RE:
If by original VIN you mean the 98 VIN, thats the problem.
The Predator is looking for an 04 Vette VIN in order to work in that car.
Jesse could do this for you I am sure. I cant say for sure that I have ever seen a Predator work with a 98 PCM, but I suppose if it is programmed properly, it will be OK.
