Adjustments for stalled trans with u7198...02 camaro
boola1341
Post by boola1341 »
I have a 02 Z28 camaro and I'm about to get a built transmission with a transgo shift kit and 3000 stall. What adjustments will i have to make if any to insure proper shifting??
2002 A4 LS1 Camaro
Pacesetter Long tube with ory
Flowmaster Catback
3.73 gears with a Auburn differential
Slp air lid and msd wires with ngk tr55 plugs
Best time is 12.89@109 with a 2.0 60' on BFG Kdws street tires
sickREDsierra
RE: Adjustments for stalled trans with u7198...02 camaro
Post by sickREDsierra »
i would assume get a custom tune from Mike, where he can lock your converter at a certain speed, and unlock it at WOT. i dont think your tool has the end user capability to do that.... Mike can hook that up though.
i have mine locking at part throttle about 55 mph... and unlocked fully at WOT. may want him to lower line pressure at part throttle shifting as well... as the aftermarket trans will have different fluid flow and accumulator springs/servos than your stocker.
2007 Sierra, 370 C.I. , Custom CompCam, ProEdge 3600 converter, 4.11's with eaton LSD, Foose 20's, DynoTune Nitrous, Patriot CNC'd heads
boola1341
Post by boola1341 »
Thanks for the info.
2002 A4 LS1 Camaro
Flowmaster Catback
