Been awhile, but I'm back with a ls1 hot cam question.......
Redgto04
Post by Redgto04 »
Hey guys, I just put in a LS1 Hot Cam. It will idle if you feather the gas on startup. Also I was logging missfires, and I get 1-4 everywhere, and about 30 on number 3. Wasn't doing this before the cam, so i put in a new plug, and wire on number 3, and it still does it. Is this just because of the cam? I will be getting a tune in a couple of weeks. I was wondering if Mikel, or Monte could do anything up to get me by untill then. Thanks guys! P.S. The ls1 hot cam is 218/228 .525/.525 on a 112 lsa. Thanks again for any input!!!!!!!!!!!
RE: Been awhile, but I
Cams will cause misfires, thats normal.
Post the tune, we can disable the misfire monitors for the meantime...
Redgto04
Post by Redgto04 »
Ok...Here is my current tune. So can u do me something up to get me by for a few weeks? The cam is a 218/228 .525/.525 lift 112lsa Thanks! I would like it to idle close to stock........Thanks again!
randy_diablew_tune_lt.grg
(256.85 KiB) Downloaded 63 times
Sorry, we'll also need a copy of the backup file as well.
Redgto04
Post by Redgto04 »
Ok...here is my original backup! Thanks man! How close do u think the tune u do will be? Thanks again!
6g2vx12g84l285348.grg
(323.97 KiB) Downloaded 70 times
Try this:
randy_diablew_tune_lt_mf.grg
(256.86 KiB) Downloaded 81 times
Redgto04
Post by Redgto04 »
What changes if its ok to ask....Thanks!
Disable misfire monitors....
Redgto04
Post by Redgto04 »
ok....so I still need to stay out of wot, but will get tc lockup now?
Redgto04 wrote:ok....so I still need to stay out of wot, but will get tc lockup now?
Well, only thing thats going to change now is you wont get misfire codes...
