2005 Mustang GT Tunes
Reedawgg
Post by Reedawgg »
I've been trying to find a breakdown of details on what each Performance Tune modifies? Any help on this is greatly appreciated. Thanks!
RE: 2005 Mustang GT Tunes
Way too much stuff to list.
Timing and fuel are optimized. throttle response is improved. and much more.
Reedawgg
Post by Reedawgg »
When I plug the tool in and go to the Performance Tune menu.. It gives me a list of various tunes to select from. I'm wanting a breakdown of each one. I installed the C&L Racer 95mm cold air intake kit on my 05 GT automatic tranny. I keep getting errors about MAF and OBDI.. Any help woould be appreciated. Thanks!
Reedawgg
Post by Reedawgg »
Oh and I do have the CL7140 :)
Are you running a C&L Racer intake?
Reedawgg
Post by Reedawgg »
They haven't released the intake itself yet that I know of. But I do have the CAI kit from C&L. Just installed it this past weekend and tuned it with C&L 91/93 octane performance tune.
Reedawgg
Post by Reedawgg »
To be exact. I ordered the C&L RACER Air Intake Kit with the Predator from rpmoutlet.com and added a MOTOBlue throttle body spacer as well.
You'll need to list the codes, as I am not sure what the issue could be.
Reedawgg
Post by Reedawgg »
Yesterday I cleared the codes and re-installed the tune. As of right now I haven't had any more error codes. When they come back up I'll post the info on here. Thanks Mike!
Reedawgg
Post by Reedawgg »
2 codes again at the moment..
P0506 Idle Air Control System RPM Lower Than Expected
P1000 OBD Systems Readiness Test Not Complete
I have gotten these codes several times after clearing and re-installing the tune.
Not sure what would cause the lower idle, try raising it a bit in the tune?
Reedawgg
Post by Reedawgg »
Rasied the rpms on drive and neutral options. Still getting the same thing. Do you think since I added a throttle body spacer by MotoBLUE from rpmoutlet.com would affect anything? Also, I've been searching the forums and trying to learn more about what the WOT and MAF adjustments will/won't help. Haven't found much help.
Reedawgg
Post by Reedawgg »
Still receiving the same erorrs in my car. Is there a possibility that I may have a bad tune?
Reedawgg
Post by Reedawgg »
Could I get some help on this please? I only have 30 days to return my stuff to rpmoutlet and I can't be out any more money. Thanks for any help in advance
tuningss
Post by tuningss »
Take the spacer off and see if that makes a difference.
http://www.tpctuning.com
Return to “Predator Ford Gas”
