03 puck, map sensor plug wires
- lap_traffic
I need to know what colors go where in the plug at the map sensor on the plug. I went to the dyno last weekend, and the puck wasnt working. I moved the wires at the plug and they (all 3) came out. So I was wondering which order do the wires go, so I can put it back together.
03 Dodge 2500 4x4, diablosport predator/puck, 2nd gen intake, airaid filter box, 6" GR stacks, leveled,
- BigBlackDodge
RE: 03 puck, map sensor plug wires
Come on 'Community' can't someone help this guy out? I'm interested cause mine has never worked right to start with! Kinda hoping something similar is all that's wrong with mine. I plug mine up and it causes codes and kinda puts the truck in 'limp mode.'
Not one of us knows what the future holds! So the real question is...do you know the one that holds the future?
Re: 03 puck, map sensor plug wires
I didn't think the install was all that difficult, I mean the plugs are color coded, but maybe this will help:lap_traffic wrote:I need to know what colors go where in the plug at the map sensor on the plug. I went to the dyno last weekend, and the puck wasnt working. I moved the wires at the plug and they (all 3) came out. So I was wondering which order do the wires go, so I can put it back together.
http://www.diablosport.com/downloads/ma ... _D7157.pdf
03'/305 Dually 4 x 4
Platinum FASS/150,/Level II CP3, 60hp.Inj.
Stage 1 cold air box, BD Intercooler
Smarty SSR,62/65/13ss, CFM+
Goerend Trans. Westach, Fuel/Rail Gauges
2011 Laramie Longhorn All Stock
RE: Re: 03 puck, map sensor plug wires
I think he means the wires came out of the plug itself.
Reg
2005 3500 Quad Cab Laramie L/B
Predator, AFE stage II, boost fooler
Pillar Mount gauges Billet low stall TC
It may be tough to help, since there have been changes in production.
I would suggest you fill out an rma request and send it in for repairs.
