2009 U7164 Update Info
Posted: Tue Mar 03, 2009 11:26 am
by dawg
I attemted to load a u7164 with the 9r09 update installed and I am
getting a Feature not supported unit 1 8c3a-14c204-yf
unit 2 8c3a-14c337-db I chkd before any Ford Updates and after
the latest update no good this is a 2009 Ford F350 S.R.W. auto. 6.4
RE: 2009 U7164 Update Info
Posted: Tue Mar 03, 2009 11:52 am
Looking into this.
U7164 Tunes
Posted: Wed Mar 04, 2009 7:22 am
by armentrout2
Mike, I tried the 80 hp tune and did not like what it was doing to the transmission i.e. shifting like an old B&M shift kit on a throw away tranny :) I experienced some of the same initial delay and power surge that other folks are talking about. It will pin you to the seat, but it's a little annoying during everyday driving and even light towing. Next I tried the 50 hp tune which did not seem any better if as good as stock to me...I did not run it long enough to get a good check of fuel economy. I am looking forward to trying the tow tune today, since that is what I have used most in the past. I have stock exhaust and a Airaid Drop Filter, so I won't be using the 160 hp tune. Hopefully the tow tune does the trick. Standing by for refinements...Thanks!
Re: U7164 Tunes
Posted: Wed Mar 04, 2009 11:22 am
armentrout2 wrote:Mike, I tried the 80 hp tune and did not like what it was doing to the transmission i.e. shifting like an old B&M shift kit on a throw away tranny :) I experienced some of the same initial delay and power surge that other folks are talking about. It will pin you to the seat, but it's a little annoying during everyday driving and even light towing. Next I tried the 50 hp tune which did not seem any better if as good as stock to me...I did not run it long enough to get a good check of fuel economy. I am looking forward to trying the tow tune today, since that is what I have used most in the past. I have stock exhaust and a Airaid Drop Filter, so I won't be using the 160 hp tune. Hopefully the tow tune does the trick. Standing by for refinements...Thanks!
OK, let us know.
Also, remember that you can add or remove line pressure in the adjustable parameters, so if you want to try to soften up the shifts a bit, go for it.
Mike
Re: 2009 U7164 Update Info
Posted: Fri Mar 06, 2009 10:47 am
dawg wrote:I attemted to load a u7164 with the 9r09 update installed and I am
We have added these to a test crom, hopefully we can release it next week.
Checking on the 09 Update
Posted: Thu Mar 19, 2009 3:32 pm
by dawg
2009 Ford F350 srw update beyond 9r09 . just checking on the progress.
