u7191.............(166770 over the bar code)
v.8r09
2005 pontiac GTO 6sp man
I ordered the cat eliminator pipes for my car. I have read that the Predator can program the rear o2 sensors out. And I have seen the link where there are hardware pieces that wire into the o2 sensor wires, eliminating the sensor, or tricking the pcm into thinking they are still there.
When I do replace the cat eliminator pipes, what is my next step in having the predator eliminate the rear sensors from the diagnostic part of the cars PCM? I am saying I guess, that it will code the missing cats and I need to have that portion turned off. I will turn the temp detectors all the way down to shut that part off, but will that turn the cat sensors off?
Russ
Eliminating Cat converter, what next?
RE: Eliminating Cat converter, what next?
That version of the Predator will let you disable the rear O2 codes.
OK thanks. Almost too easy!
Russ
Russ
