93 octane
chris098
93 octane
Post by chris098 »
part # 7146
v.9r07
03 ford mustang
Would I have any problems if I used 91 oct with the 93 oct tune?
amsounds
RE: 93 octane
Post by amsounds »
Hi chris098,
Yes you would have problems if you did that!( Detenation) I suggest you decrease your timing by 1* to 2* degrees which will put you around the 91 Octane level. You accomplish this in the global Spark settings , and listen for pinging or engine knock! Don't use Octane booster's either, they don't work!!!!!
Albert Mac
2006 Roush Stage 1 F150
4x4 Supercab
Mildly Modified By Troyer Performance &
DiabloSport Tuning
www.Troyerperformance.com
www.Roushperf.com
Phil
RE: 93 octane
Post by Phil »
Always run what octane that is required for the tune so you don't run into any issues. If you can't get the correct octane fuel you can always make timing adjustments to compensate for this.
Phil Jones
Diablosport Inc.
Tech Support
Please do not PM us for tech support, post up first!!!
Return to “Predator Ford Gas”
