OK Guys.....question....MonteSS Step in please!
Redgto04
Post by Redgto04 »
Ok, I added a ls1 hotcam kit to my GTO along with a underdrive ballancer. I also have LT's, and no cats with spintech mufflers. I just got a tune this weekend, and she put down 368/374. It seems fine, and I think I am going to keep my Predator for small things. My question is this, On the 70 mile trip home, i was watching my LTFT's, and they were staying about a +7 at 2300 RPM. When we tuned it it was mainlly on the Dyno WOT, we only cruised around for about 15 mins messing with the shifting. OK if I mess with my cruise LTFT's now, will it affect any of his tuning? Thanks guys!
CANUCKPREDATOR
RE: OK Guys.....question....MonteSS Step in please!
Post by CANUCKPREDATOR »
part throttle fueling DOES effect the wot fueling. If you adjust them, you should go back to the dyno to readjust your WOT
yeah, they should'a tune it right - need to do part-throttle tuning first, then WOT tuning...
what you CAN do tho is... go -7% on your injector slope to get your part-throttle fueling dialed in...
then go into the PE fueling section, and also go -7% in all rpm ranges...
this will essentially remove the extra fuel at WOT that is added by goin -7 on your slope adjustment, so that your PE/WOT fueling should stay at about the same level as what they adjusted it to be for your WOT AFR...
