Purchase of U7134
buddy511
Purchase of U7134
Post by buddy511 »
I do not have a Predator yet I would like some clarification on the Predator for a 2004 GT Cruiser with Sg 1 Comp. There seems to be problem in Forums getting the downloads to work for the Cruiser, Is this systemic or a random feature with car? Also does the Predator help w/the Transmission shift and upshifts. Thanks
sfla_srt4
RE: Purchase of U7134
Post by sfla_srt4 »
Its probably based on you Cal ID number.. They have updates every so often, so they will eventually all get supported.. If you recieve a Predator and it needs the update, Diablo will get you an update.
turbofan
Re: Purchase of U7134
Post by turbofan »
buddy511 wrote:I do not have a Predator yet I would like some clarification on the Predator for a 2004 GT Cruiser with Sg 1 Comp. There seems to be problem in Forums getting the downloads to work for the Cruiser, Is this systemic or a random feature with car? Also does the Predator help w/the Transmission shift and upshifts. Thanks
it's random, but if you have a problem, they WILL work it out for you, takes anywhere between a day or two and a week or so.
the predator has not yet been updated with auto trans shift firming like the stage 1 does, but if you use it in conjunction with your stage 1 pcm, you'll retain the shift firming you got with stage 1, along with the other benefits of the predator.
are you on PTCrew?
buddy511
RE: Re: Purchase of U7134
Post by buddy511 »
No, I am not but Thanks for thre Info
turbofan
Re: RE: Re: Purchase of U7134
Post by turbofan »
buddy511 wrote:No, I am not but Thanks for thre Info
i highly recommend PTCrew, www.ptcrew.com
pretty much anything you'd wanna know about the PT, you can learn there. there's a ton of info about the Predator there as well, and there are several of us who own and love predators on the site.
hope to see you there!
buddy511
RE: Re: RE: Re: Purchase of U7134
Post by buddy511 »
Thank you very much for the info, I joined the ptcrew and I will order a Predator soon, I'll definatelly keep you in mind when this up on the GT
