Hi,
I have a 93 oct tune on my 06 RT charger. Currently it shifts gears at 5500 rpm. I would like to bump that up to aleast 5800. I would also like to take the top speed governor off. I do not have any other modifications to my vehicle as of yet.
I tried to download the Custom Hemi tunes instructions, but I got an index.php file instead of a Microsoft Word document.
If someone could guide me through this process, I would greatly appreciate it.
Thanks in advance
RPM and top speed limits
RE: RPM and top speed limits
Shift points canbe set in the quick adjust menu, and the speed limiter (which is already set to 170 MPH) is in the modify tune menu.
The only choice we have to raise the shiftpoints is 6000 RPM and not 5800 RPM ... while 5800 is ideal, 6000 is a little too high, So if we put it at 6000 RPM, and at stock auto uphift mode , can we still shift it manually under full throttle at 5800 RPM or it will still go to 6000 RPM?
The shift points are presets that we use from DCX, so there are only a few options.
You can still manually shift it where ever you like when in autostick.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
