Nitrous and ST knock Retrad
Dodgetony
Post by Dodgetony »
I ran my 09 RT Auto today logging data using a ZEX 100 horse shot. I am getting 2 ~ 6 degrees ST spark knck. Without the nitrous I dont get any.
For the nitrous runs I pulled 3 degrees timing all across the board, and added +4,+7,and +9 on the fuel. My A/F ratio is 12.7.
What should I do?
Quick
RE: Nitrous and ST knock Retrad
Post by Quick »
A/F is 12.7 with or without the nitrous?
You might want to get plugs a step or two colder as well (copper is preferable).
Most guys I know running nitrous have 2 tunes. Track and street (nitrous and no nitrous).
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
Dodgetony
Post by Dodgetony »
My AF is 12.7 with the nitrous.
I plan on running separate tunes for the nitrous. My main question is, is the amount of knock retard I am seeing on nirtrous a problem?
I am running one step colder plug (NGK 4306) which is a copper plug.
Quick
Post by Quick »
Dodgetony wrote:My main question is, is the amount of knock retard I am seeing on nirtrous a problem?
I don't know. I think 2* is ok if it's just a couple of bumps and not constant.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
SRT8Tech
Post by SRT8Tech »
Might wanna add more fuel. I think 12.7 is still a bit lean for N2O.
2013 SuperBee......................................................
Dodgetony
Post by Dodgetony »
SRT8Tech wrote:Might wanna add more fuel. I think 12.7 is still a bit lean for N2O.
I was wondering about that. I will add more and see if that helps with the knock. I dont want to keep pulling timing if I can correct it with adding fuel.
Quick
Post by Quick »
I'd go all the way down to 11.8/11.9 before I pulled any more timing but I don't know much of anything about running nitrous
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
Dodgetony
Post by Dodgetony »
So...I spent the morning tuning and data logging. I got my AF down to around 11.9~12.0 at WOT. I pulled 3 degrees and still get anywhere from 2 ~ 6 degrees ST spark retard. I get absolutely none with the AF at 12.7 and no timing pulled when running NA.
I am ready to pull my hair out.
Quick
Post by Quick »
Ummm.... just checking. You're NOT running a dry system are you? And you ARE using a wideband and not just looking at the commanded A/F right?
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
Dodgetony
Post by Dodgetony »
I am running a ZEX wet system. And I have a wideband installed in the car.
Quick
Post by Quick »
So what does the "anywhere from 2 ~ 6 degrees ST spark retard" look like in a log? Can you post a log?
Is it continuous? a lot of bumps? a few bumps? where? random? particular rpm ranges? right after/around shifts? etc. log would be best.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
Dodgetony
Post by Dodgetony »
I am sure this has been asked before, but how do I post a log?
johan
Post by johan »
From what i have seen on nitrous cars, the st knock is very hard to tune out without raising the knock thresholds, something you really dont want to do when running nitrous.
It must be the higher cylinder pressure caused by the nos creating more "noise" that the sensors pick up.
I doubt you will be able to tune it out.
What is the actual spark you see during the run?
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Dodgetony
Post by Dodgetony »
johan wrote:From what i have seen on nitrous cars, the st knock is very hard to tune out without raising the knock thresholds, something you really dont want to do when running nitrous.
The spark goes from 40's down to 10. The 10 occurs when the ST retard is around 5.5 at 5570 rpm's.
This is with 4 degrees timing pulled on the 93cai tune using 94 sunoco gas. (100 shot of nitrous).
ElectricBlueHemi
Post by ElectricBlueHemi »
You might try the 87 octane tune and see how it does. That works for many people.
