puck for 6.4
puck for 6.4
I have a puck for the ford 6.4 diesel stacked with the predator. The question is, is there any way to data log with the predator to see if the puck is working properly. The puck seems to make no difference in performance. I will check all the connections in the meantime. Thanks
RE: puck for 6.4
I have the same set up, and mine is the same. I really don't notice a difference either. Is there anyway to tell if the puck is working. I thought there would bet a big torque difference but there is'nt.
RE: puck for 6.4
You could monitor fuel rail pressure to see it commanding more pressure.
RE: puck for 6.4
can i do this with the predator???
RE: puck for 6.4
Yes.
RE: puck for 6.4
OK so where do I find the fuel pressure at. Cant find it in the real time data, and the data logging I guess doesnt work. So help please.
RE: puck for 6.4
yeah me either...glad i'm no the only one.
RE: puck for 6.4
I'll have to go through the PID list, it has to be in there.
RE: puck for 6.4
You guys should have that info a little more accessable. I would imagine it would save alot of time.
RE: puck for 6.4
The PID should be FUP measured in KpA.
RE: puck for 6.4
There is nothing in the PID list that is even close to having anything to do with monitoring fuel pressure. I would think you would notice the extra 100 hp if it were working. If the retailer will call me back I could get it replaced. This my take a while. Do I have any other options?
