Cat c-7
Posted: Mon Mar 30, 2009 4:47 pm
by Mopac
Hey guys this is the 4th time i have tried to put this thing on our work truck, which is an 04 ford f-650 with a c7 cat motor. I looked at the diagram in the other fellows post, and my motor doesnt have a separate map sensor harness connector. I can find the ICP one but not the map. Is it different cuz its a ford truck? it is a january build date. Thanks guys
RE: Cat c-7
Posted: Mon Mar 30, 2009 5:27 pm
There will be no difference in the connectors. It doesn’t matter what vehicle the motor is in, it will be the same setup on the motor. Check the wire colors in the connectors. It will either connect at the sensor or to a pigtail off of the MAP sensor. The wire colors are the main thing you need to look at.
Mike
