Estimated HP increase?
Bdogg
Post by Bdogg »
What is the estimated Horsepower gain for a 2009 Dodge Challenger RT...5.7L Manual Trans...Using the 93 Octane performance CAI tune?
RE: Estimated HP increase?
20hp 20ft/lbs
Bdogg
Post by Bdogg »
Thanks Mike...What are some of the adjustments in this particular tune? Does it increase the rev limiter also?
There is an option to advance the limiter, yes. You can also adjust the speed limiter, adjust for gears and tire sizes, and tweak the timing and fueling.
Bdogg
Post by Bdogg »
so hypothetically, would I start be flashing a loaded 93 octane CAI tune, and then make adjustment to the rev limiter? (or any other specifics)or does this particular tune adjust it?
I see that the predetor has the option for customization, but not knowing too much about it I fear messing it up
I have just purchased the predator, and just trying to better understand the specifics, before connection....Seems like a great product...thanks for the feedback
Nazab
Post by Nazab »
Yes you first download the 93 CAI tune and then change whatever you like ... don't touch customizing ... only quick adjusts... enjoy it.
johan
Post by johan »
We already bump the rev limiter in the canned tunes so you can raise the shift points without having to adjust the rev limit.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Nazab
Post by Nazab »
so in the 5.7L 91 CAI tune, at what RPM have you set the rev limiter as I think in mine I don't have any rev limiter !
It would be at 6200 RPM
Bdogg
Post by Bdogg »
with the manual transmission, what does increasing the shift points, as opposed to the canned increase of the rev limiter do?
Which one will enable the engine to not force you to shift @ stock setpoint?
What is the stock set @ in the 2009 RT Manual?
