My 2005 GTO Data Log for help
OMENOUS
Post by OMENOUS »
getting a lot of knock retard and other funny things... i noticed my fuel trims are pretty decent but my timing might be bad??? i had no idea what or how to log and what was actually needed but this was the best i could do. no WOT's cause i was afraid of the knock. any help would be greatly appreciated.
Ethan
btw can you tell me all that is needed to be data logged or should i just log it all like i did? i noticed it filled fast on the predator... sorry none of my laptops currently work.
06 Trailblazer SS
05 GTO
98 Corvette
RE: My 2005 GTO Data Log for help
the parameters you need to log are all listed in the info:
you need LTFT bank 2 as well....
OMENOUS
Post by OMENOUS »
okay, read over the sticky(sorry im not usually noobish and use the search button) and i got everything to log i would say normal driving rpm is between 2200-2500 rpm on the freeway till its full. do you need WOT pulls at all or should it be fine without them? like i said earlier im afraid to do it because of all the knock under moderate acceleration. so the other stuff is definatley what i'll get ya tonight. almost had a catastrophic failure this evening... forgot to plug the electrical fans back in... oops... good thing i caught it early. i can install and tear down anything but when it comes to electronics im all thumbs. Thanks for the help.
06 Trailblazer SS
05 GTO
98 Corvette
