Won,t Load on my pickup but loads fine on others.
strokethis
Post by strokethis »
My Predator won't load on my pickup, it says backup not saved, I did remove my old tuner which was a SCT LIVEWIRE JUNK!!!!!, but now the predator wont load in my pickup. Version is the one you just sent me 7r19dz and the stragety is VRAA7S8. I don't know if you can help me or if I need to have dealership reflash the computer.
Thanks,
Brent Kulp
Its not what you buy, it what you build.
predator programmer,adjustable HPOP module, Overboost eliminator, intake, 5 inch exhaust, banks wheel, built trans, manual lockup switch, 315's and 100hp sticks. 400hp and 900ft lbs to the ground.
RE: Won,t Load on my pickup but loads fine on others.
Try going in to the tool and select options/troubleshooting/verification, set it to OFF, then try to instal the tune again.
Be SURE to remove the tool from the other truck before attempting to install it in yours.
strokethis
Thanks for the fast response, I will try this tonight, also I do some tractor pulling with my pickup, what does it take to do some custome tuning to work with some 100hp injectors.
Thanks,
Brent Kulp
