2009 Supercharged Challenger
Posted: Mon Apr 13, 2009 3:20 pm
by davenportmotorsports
I would like to know which table I should adjust to add timing while in a boost condition. I am starting with a base supercharged tune, but would like to tweak it. I have tried adding some of the tables, but my scanner still shows the same timing.
RE: 2009 Supercharged Challenger
Posted: Tue Apr 14, 2009 2:17 pm
by johan
Main one is the WOT spark table, make sure to check the map scaling and see if it has been changed then log at what map the vehicle is at where you want to change it, then change the values in those areas.
