Torque Converter lock up
Posted: Mon Apr 13, 2009 9:40 pm
by Excursionist
Brian are you there? In the latest Tune files I am having acceleration problems at highway speeds. At 70 mph if I punch it to the floor it downshifts and begins to accelerate as usual, then it up shifts then downshifts then upshifts again. It does this several times so I have to just let off the accelerator and not pass. Never had this before with the old predator. Had this problem with Superchips but downloaded that tuner and benched it.
Unrelated but what is KAM? Keep Alive Memory. What happens in a reset of this.
RE: Torque Converter lock up
Posted: Fri Apr 17, 2009 7:57 pm
by Excursionist
Hey no answer on this post yet. Anyone there?
Re: Torque Converter lock up
Posted: Sun Apr 19, 2009 1:19 pm
by jbeasts10
Excursionist wrote:Brian are you there? In the latest Tune files I am having acceleration problems at highway speeds. At 70 mph if I punch it to the floor it downshifts and begins to accelerate as usual, then it up shifts then downshifts then upshifts again. It does this several times so I have to just let off the accelerator and not pass. Never had this before with the old predator. Had this problem with Superchips but downloaded that tuner and benched it.
Mine done the exact same thing.(weird shifting that is).I loaded the 9r04 and bumped the line pressure up..problem solved.Hope this helps.
Posted: Tue Apr 21, 2009 5:18 pm
by strokethis
I ran iinto the same problem but is was because my torque converter had a malfuncition and wouldn't hold up to the power, the warmer the vehicle got the worse the problem, try driving it cold and see what it does. This was a brand new out of the box converter with tripledisk lockup, billet front cover and so on.
Posted: Tue Apr 21, 2009 6:26 pm
by sohfast94
Lastest tune files?! last time we spoke you were good were you not?
Posted: Fri May 08, 2009 12:21 am
by Excursionist
sohfast94 wrote:Excursionist wrote:Brian are you there? In the latest Tune files I am having acceleration problems at highway speeds. At 70 mph if I punch it to the floor it downshifts and begins to accelerate as usual, then it up shifts then downshifts then upshifts again. It does this several times so I have to just let off the accelerator and not pass. Never had this before with the old predator. Had this problem with Superchips but downloaded that tuner and benched it.
Last time we spoke I had just got the tuner back upgraded from diablo untested. My line pressure is not a problem. Driving it cold makes no difference. its not the tranny or converter. Had this problem with a Superchips tuner and got rid of it and went back to the Diablo tuner with no problems. this was just before I sent it in for the upgrade. Was trying Superchips because of the Theft System problems I was having with Diablo and no support.
RE: Re: Torque Converter lock up
Posted: Sun May 10, 2009 3:33 am
by Excursionist
So here we are again just like before when I turned to Superchips..No Brian(Sohfast).. and no support?
