Installed Tune and now car won't start
pk09
Post by pk09 »
The important stuff:
Serial: d007798
Part: u7144 svt_focus
Version: v.9r04
Hardware: UNIV_REV2
Part Number: 222912
Vehicle: 2003 Focus SVT
The other day I was putting this tune back on after having the factory tune on for a while. I decided that the tune that came with this was better, so I went to put it back on. The tune went on fine and everything seemed to work....Until this morning. I tried to turn my car on and when the key got to the point where it usually fires right up, it just clicked. Please help! Thanks
RE: Installed Tune and now car won
Sounds like a dead battery to me....?
dbqking
Post by dbqking »
starter went ????? doesnt sound tune related at all
pk09
Post by pk09 »
It's not the battery...Granted, I got a new one cause it still had the original and the cranking was low. The tuner won't recognize the car now and all electronics work so it's not a fuse, unless the ECU has a seperate fuse but I'm pretty sure it's the same as some other things. The car does nothing mechanically. It doesn't even try to start it's just that you turn the key and nothing happens. It'd never hesitated to start before, not even in -40 weather. Thanks for the input so far! Hope this clerifies
If the car was running fine and this just happened out of the blue, it has nothing to do with the tune.
Return to “Predator Ford Gas”
