Unlock U7198
vigilanti
Unlock U7198
Post by vigilanti »
Hi need some help. I just bought a used U7198 for my 02 Camaro Z28.
The unit shows locked. How do I unlock it? Do I need some code?
Thanks guys.
RE: Unlock U7198
If this tool has a revision displayed on the top line of the main menu reading version 1.03, and under Options>car tune it reads 'factory tune', this tool can be unlocked for $99+shipping. If both of those two criteria cannot be met the tool cannot be unlocked.
vigilanti
Post by vigilanti »
I'll look. I guess I should have done some reshearch first before I bought one of these. Now I think I owe my friend 75 bucks for borrowing his
brand new one. His will be locked to my car......Bummer! How come this isn't mentioned anywhere. I thought I read this Tuner would do up to 5 cars or trucks? Thanks for the help.
Not sure how you mean your friends is locked to your car. If the one you borrowed is restored to stock in your car, it should be fine.
All of this information is readily available, and is in the owners manual. Nowhere does any of our literature say these tools will work on more than one vehicle at a time. If you properly restore the backup file to the vehicle the tool is married to it can be used on any other supported vehicle.
Where did you read that it would do 5 cars or trucks?
The U7198 does work on any 99-02 GM gas V8 trucks, 99-02 Camaro/Firebird LS1 and 99-03 Vette LS1/LS6.
vigilanti
Post by vigilanti »
So If I reinstall the factory tune back in my 2002 Camaro this will unlock my
friends new tuner ? What I read was the tuner could hold upto 5 tunes. I mistook that to mean you could tune upto 5 different cars or trucks. Also It looks like you can unlock my used one. How do I send it back to you?
Thanks again.
P.S Can I fix the speedo with my friends tuner without it getting locked
to my car? Just untill I get mine bacK.
vigilanti wrote:So If I reinstall the factory tune back in my 2002 Camaro this will unlock my
Thanks again.
Yes, put your car back to stock and return the Predator to your friend, no problem. You can not use it to alter the tune in your car without marrying it.
I still need to know if the other tool is on the 1.03 revision and has been restored to the vehicle it was used in.
vigilanti
Post by vigilanti »
My used tuner has the 1.03 revision and car tune showing just like you asked. The factory tune was not reinstalled. I bought this from someone in
Florida I live in Mass. I believe you said you could unlock it for me. How do I send it back? Do you want me to call Diablo Sport?
Thanks Mike.
Yeah, I'm a bit confused.
Please call us with the Predator powered up so we can get this straightened out for you.
vigilanti
Re: RE: Unlock U7198
Post by vigilanti »
mikel wrote:If this tool has a revision displayed on the top line of the main menu reading version 1.03, and under Options>car tune it reads 'factory tune', this tool can be unlocked for $99+shipping. If both of those two criteria cannot be met the tool cannot be unlocked.
Both of these criteria are met. However Gary told me that although this
criteria is met I would still have to have the unit sent back to the original
owner, he would have to load the factory tune back in his truck, then I
couild send it back to you to upgrade the unit so I could use it.
RE: Re: RE: Unlock U7198
You seem to have missed the part about car tune showing 'factory tune'.
This was the second part of the criteria that needed to be met.
vigilanti
Post by vigilanti »
Ok my bad. It shows Diablo Tune after car tune. Is this ok? The guy from
Florida sold his truck so am I stuck? Is there any way possible to unlock
this thing?
Thanks Mike.
No, it must be restored to that truck in order to unlock it.
vigilanti
Post by vigilanti »
Ok bummer.What is the differance Between a SLP Diablo Sport II
27007T and the U7198 ?
Thanks.
The SLP tools have their own tunes on them designed around their performance packs.
vigilanti
Post by vigilanti »
One last question cause I'm still a little con-fused.....If the guy that owned
my used one had reinstalled the factory tune back in his truck, wouldn't my used unit have been unlocked. I don't understand your offer of 100 bucks to unlock it? But yet you said my friends new unit will be unlocked once I load the factory back in my car ? Will I still have to send his back you ? Sorry for being so stupid.
Thanks Mike.
