When Would I Need A MAF.i.a?
shoreboy725
Well I have tried reading up on the MAF.i.a and I'm trying to understand it. I'm just not too sure when and if I would actually need a MAF.i.a on my truck. I have a 2004 Ford F150 5.4 Triton 3v. I'm planning on adding a cold air intake, pulley, electric fans, alum. radiator, Predator programmer, straight pipe exhaust, lower thermostat, bigger throttle body and spacer, pretty much all the everyday performance stuff. I'm also adding the Stage 2 MAF Boost Cooler. Should I be concerned with upgrading the MAF and/or adding the MAF.i.a? Thanks for the help.
RE: When Would I Need A MAF.i.a?
Well, the MAFIA is for boosted applications to extend the ueable range of the MAF, not needed in a N/A application.
Also, why the boost cooler?
shoreboy725
Well, it said it could be used on N/A and I guess it's called the Boost Cooler to keep all the product names the same. It said it will spray the mixture into the intake depending on manifold vacuum and can be tuned for either power or fuel economy.
