safe to tune?
matt197
safe to tune?
Post by matt197 »
hoping someone can answer this but, i ended up getting 2 vins in my computer, sent in my predator to get reset, did that, and then my computer wasnt any good. My old pcm thought it was a manual....i installed a tune into it to see if it would change anything and it didnt, so i went and bought a new pcm
Now im curious if the predator can tell a difference between a manual truck and an automatic. To be honest im scared to install it after my last round of problems. I dont want to install it and then make my new pcm think its a manual transmission when its not(thus messing up the new pcm). Can a predator do this??
RE: safe to tune?
Your problem was due to the fact that your tuner was locked to another truck and you let it restore a stock tune to your truck that did not belong to it.
As long as the tool is reset, and only used in your truck properly, you'll be fine
matt197
RE: safe to tune?
Post by matt197 »
okay, is there a way to check to see if it reset?
RE: safe to tune?
Options/show last tune written should say original backup.
duallydave
RE: safe to tune?
Post by duallydave »
i swapped the 7130 back and forth with my dads 03 manual and my 04 manual,i wonder if we swapped vin sometimes,we both have manuals so i guess it wouldnt matter eitherway,he wouldnt give it back the last time so i had to get another one haha
04 l/box.predator quad race x2 cammander.bhaf.6spd stick.
Re: RE: safe to tune?
duallydave wrote:i swapped the 7130 back and forth with my dads 03 manual and my 04 manual,i wonder if we swapped vin sometimes,we both have manuals so i guess it wouldnt matter eitherway,he wouldnt give it back the last time so i had to get another one haha
As long as you restore properly between trucks, you are fine.
matt197
RE: Re: RE: safe to tune?
Post by matt197 »
thanks for the help, tune went in flawlessly. boy does she smoke a lot now with the new lift pump!!
Re: RE: Re: RE: safe to tune?
matt197 wrote:thanks for the help, tune went in flawlessly. boy does she smoke a lot now with the new lift pump!!
Glad to hear it.
