Camaros SS - DTC P0137 H02S circuit low voltage error
When I run my Camaro SS on the predator, I contiually get the P0137 and P0157 error codes. The car is stock except an SLP air lid. Car is an auto. I have run the car for a few weeks, seems to run OK on the predator, although I do not want to run any further until I know that everything is OK. Is the car running lean, should I be modifying some parameters to solve this? Any help would be great....
FYI - no error codes without predator tune.
LightningMike03
Just looking for some additional information:
P0137 - O2 sensor low voltage error.
Have you made any modifications to that circuit? Cut a wire, done any soldering or splices or moved the sensor?
I know you said that the codes only occur on the Predator tune but there may be some sensitivity in the O2 circuit that only shows up when on the modified tune.
Predator revision?
Have you modified the tune at all?
mikel wrote:Predator revision?
Ok, that is the revision.
Have you tried reinstalling the stock tune to see if these issues still happen?
Strange, I will have to look into this.
