Page 1 of 2
need a diablosport tech to contact me!
Posted: Sun May 03, 2009 9:13 pm
by buzzkill
I need to get in touch with one of you Diablosport techs. I am having my car (2005 SRT4) tuned by a cmr tuner and there are some error codes that will not go away! He has tried countless times through different tunes but they still come back when they shouldn't (especially overboost code).The info from my car was sent to you over five weeks ago and still no remedy.
Please pm me with an email address so I can give full details including tuners email so you can get in contact with him directly. Thank you.
RE: need a diablosport tech to contact me!
Posted: Sun May 03, 2009 10:18 pm
by tensix
The tuner is getting error codes or your car is throwing codes? Overboost codes are common when boosting over stock psi. A stage 1 pcm will do away with the overboost codes.
Posted: Mon May 04, 2009 6:48 am
by buzzkill
The codes should not be occurring due to cmr custom tune. Now please techs only. If you work for Diablosport then great, i need to talk to you. If not, please dont give your opinions.Still need a tech to chime in. If the last poster is a tech, then I am sorry but there is nothing identifying you as one. Please let me know if you are and we can continue this conversation further.
Posted: Mon May 04, 2009 7:10 am
by buzzkill
Sorry guys if I came off as being rude. I am not trying to be. I just need to get this addressed asap so tuning can continue.
Posted: Mon May 04, 2009 8:42 am
by johan
Do you happen to have the tune so we can look at it?
Mods list as well...
Posted: Mon May 04, 2009 8:10 pm
by buzzkill
definitely!
mods:
3" cai
3" o2 housing
3" catless exhaust
Forward Motion WGA (pcm controlled, boosting 21, starts falling around 5000 rpm's to about 17 at 5600 rpm)
stage two injectors
Forward Motion
E1 turbo
Boomba BOV
NGK Plugs
180 degree t stat
Walbro fuel pump
W/I injection (not being used in the tune yet)
stock pcm
Tune is attached.
I get p0234 (overboost) after two or three pulls.
Posted: Tue May 05, 2009 8:31 pm
by buzzkill
Hey Johan, did you guys get a chance to look at the tune?
Posted: Wed May 06, 2009 8:45 am
by johan
Give this one a shot and let me know.
Posted: Wed May 06, 2009 12:05 pm
by buzzkill
work today but tomorrow I'll be all over it and post up. Thanks .
Posted: Thu May 07, 2009 5:55 pm
by buzzkill
well tried the tune and didnt go so well. Second gear boosted to almost thirty psi resulting in a tb vac line blowing off. After the line went, bov no workie all the way home. :shock: Not sure what was changed, but with that tune before the car boosted to around 20 psi. Let me know what you think Johan
Posted: Thu May 07, 2009 5:57 pm
by buzzkill
I am pretty sure the excessive boost is what caused the line to go, and not the line going causing boost but I'll zip tie it again and give er another go if you want to make sure.
Posted: Fri May 08, 2009 1:29 pm
by buzzkill
Hey Johan, I rezipped the line that blew off and tried the tune that you gave me again. third gear, boost went instantly to 29-30 psi and i got out of it.
Posted: Wed May 13, 2009 11:19 pm
by buzzkill
wow! thanks for the continuing support. :shock: still nothing from you but my tuner and I are working it out. Brian will be missed.
can u look at a past tune for john moore not working havent
Posted: Mon May 18, 2009 6:59 pm
by johmoore133
04 srt4 stage2 injectors full 3in exhaust cai ecu stage 1
Posted: Tue May 19, 2009 8:34 am
by johan
buzzkill wrote:wow! thanks for the continuing support. :shock: still nothing from you but my tuner and I are working it out. Brian will be missed.
Sarcasm not really necessary....
Your "tuner" should be able to figure it out i would think.
Attached a new file for you...
