r03 or r16.....need help..
blueticktx
Post by blueticktx »
alrite fells i have the rough idle thing goin on got an 06.I just changed fuel filter and cleaned air filter no luck still rough....Secondly, whats the classic sign of a bad injector have had one engine light come on tuner did not read went ahead and cleared it..have had it on the performance tune 4 about a week now..please help...
kw5.9
Post by kw5.9 »
if you have a '06 you need version 9r 03 and do a reinstall by going in to options trouble shooting and and the idle shoud smooth out and i had injectors go bad and predator couldnt read either....so do the key cycle trick to see what cel you got. 8)
Ram 2500 2007.5,5.9ctd,6spd,4X4,predator,puck,Amsoil air filter, AME amsoil, straight pipe turbo back,silencer stolen,quadzilla fooler
blueticktx
tried the key cycle trick got nothin..explain is there a proper way to do it.....
dunejunkie
Post by dunejunkie »
had same problem with mine all of a sudden, took it to the shop and #1 injector was bad. replaced injector and it runs smooth again, well as smooth as a diesel can. i guess in 06 injectors were a common problem
06 mega cab predator/puck stack,afe stage 2,cfm+ plentum,zilla boost fooler,maghytec deep trans pan, a-pillar gauges and 5 inch exhaust
johan
Post by johan »
Yeah for some reason 06's seems to display the injector problem more than any year.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
