Dodge2500 diesel shaking problem
Posted: Sun May 10, 2009 9:15 pm
by michaeld2500
When I get on the gas pedal, after it idles back down the whole truck shakes extremely bad, it stops after I let off the gas all the way. like its the engine, started after installing the chip. Problem??
689076337878
2006, dodge ram 2500 5.9L 4wd
shaking problem
RE: Dodge2500 diesel shaking problem
Posted: Mon May 11, 2009 9:44 am
by johan
When was the last time you changed your fuel filter?
Posted: Mon May 11, 2009 11:40 pm
by michaeld2500
I have not changed the fuel filter. It shook again really bad today, when I went over some really bad potholes at about 65 mph..
Posted: Tue May 12, 2009 8:23 am
by johan
That sounds like something mechanical, bad ground or something.
I personally change the fuel filter every other oil change.
Posted: Tue May 12, 2009 5:36 pm
by ranger_dog
The 65 MPH pothole thing sounds like the dreaded "death wobble" dodges are known for. Shaking from getting on the gas isn't the same thing but hitting a bump and having a severe shake is. Things that cause that are, improper alignment, worn steering stabilizer, worn tierod ends, etc. I added a 2" leveling kit and got it bad.
Posted: Tue May 12, 2009 7:35 pm
by johan
Never even heard of that but good call man..
Posted: Wed May 13, 2009 5:10 pm
by ranger_dog
If you want to see it in action, try this link
http://www.thurenfabrication.com/dwctdslow.wmv It's available on Thuren Fabrication's website. I am running several of his products on my dodge to eliminate the problem I had. Works great now and with larger tires too. (larger tires exaggerate the condition) Anyway, good luck michaeld on fixing the problem.
Posted: Thu May 14, 2009 9:53 am
by ModManiac
Your truck also has a 2 piece flywheel, Ive seen some that were shaky from this.
Re: RE: Dodge2500 diesel shaking problem
Posted: Thu May 14, 2009 3:30 pm
by ropnjessi
ranger_dog wrote:If you want to see it in action, try this link
Excellent video
