U7135 Can't turn MDS back on again ?
ivanford
Post by ivanford »
Predator U7135
Revision 9R17
Chrysler 300C 5.7 Hemi
93 Octane CAI tune
After turning off MDS with the tuner, I am unable to turn it back on again without restoring all the original parameters and starting again.
After turning off MDS the EGR also appears to be turned off, although I have not touched this parameter, again I seem unable to turn this back on either, without restoring the original parameters.
Is this a software bug or am I doing something wrong.
RE: U7135 Can
Never heard of this before, although it is normal that the EGR param gets a * when you change MDS.
ivanford
Post by ivanford »
Yes, the EGR gets a star after turning off MDS.
I have tried again and I definately can't turn MDS back on again without restoring the original parameters of the 93 CAI tune and starting again, changing tyre size, shift firmness etc.
It's not a big problem, but I thought you might want to know about it. Do you want a copy of the tune to look ?
ivanford
Post by ivanford »
Today I tried again to turn MDS back on again on my 93 CAI tune. It definately won't turn back on after it has been turned off unless you restore the stock parameters first. Then you have to change tyre size etc all over again.
