2007 Silverado Classic
Posted: Fri May 15, 2009 7:35 pm
Got the U7192 yesterday for my 2007 Silverado Classic Crew Cab 4.8L. This will be my second Diablo tuner, and fifth hand held tuner (not for the same vehicle of course). I have had excellent experience with my previous Diablo tuner, for my Mustang GT. Problem I am having with this current one is when I hook it up to the vehicle and proceed through the steps of the "Performance Tune" section, I get a message "Unable to read vehicle type (1)......."
I called Diablo this morning and Mike said to download the updated revision. I did that, and I get the same message. I searched through the forums and found a few possible causes. My battery voltage is good. I did remove the (3) fuses as stated in the instructions. Aftermarket radio faceplate is removed so it is inop. Aftermarket sound system is disconnected. I disconnected all aftermarket electrical accessories, with no luck.
When I proceed through the "Performance Tune" section, I notice my gauges will all fall to zero then back to normal, as if they are being reset. Is this a electrical issue? Or do I need to reflash my PCM?
I live in Vegas, and it is hot outside... and I just want to install the tune so I can play around with my truck again and not be pissed that I can't get it to work!!
