2004 GMC Denali - tune not 'taking'
ElectricLunchBx
Post by ElectricLunchBx »
I did several searches trying to isolate the problem prior to making a post. I apologize if there is a duplicate thread I missed. When installing the tune my transmission settings are not 'taking' (the torque management is still on and the pressure/speed of the shifts are unchanged). This is a newer predator model that I purchased in November of 2008. I completed a move during that time and lost the instructions regarding which fuses need to be pulled prior to installation. Could this be the culprit and if so what fuses should be pulled during this process? Thank you and again I apologize if this has been answered elsewhere in the forum.
CANUCKPREDATOR
RE: 2004 GMC Denali - tune not
Post by CANUCKPREDATOR »
Did it ask to install the tune, after you made the modifications to the tune?
Try raising the line pressure a bit...
ElectricLunchBx
I have used a predator in the past (My supercharged Bullitt had a custom tune loaded) and the procedure was the same. I have the line pressure up a few pounds, the speed increased and the torque management to 'off'. It is apparent the torque management is still on. I am wondering if not pulling the recommended fuses may have had an impact on it. Again, I don't have the original instructions (lost in the move) and I don't remember which fuses need to be pulled. If I could get that information maybe I could attempt to reload the tune and see if that helps?
Fuses do not matter.
Make sure you installed the performance tune and not the factory hp tune and it should be good to go.
fiero429
Post by fiero429 »
I also have a 2004 GMC Sierra Denali I have to remove fuse to tune my truck, the radio, radio amp, and info(onstar)
