Serious questions on upgrades need
6.4hemiram
Post by 6.4hemiram »
u7137 2005 hemi ram 6.4L 392 8.8 comp boost cam port and polished fully studded headman longtubes into headman 3inch y-pipe thru 2 bullets back 2 back dumped.
I would like to know what i should upgrade from stock in the fuel area of things. the motor will be making around 700 flywheel horse power.
also i was wondering if diablo sport in delray beach tunes vehicles with predators or where they would advise me to take it.and
RE: Serious questions on upgrades need
How does that even run? You definetly need injectors, probably logs, and a boost-a-pump, if not a whole new pump.
What will be making boost?
Id look into a set of siemens/deka 60# injectors at the minimum.
6.4hemiram
it has a novi 1200 on it. it runs like s*** thats why i need to know what to do and is there any way to bypass the intake regulator and do a retur system some how
Yes, you can do a return fuel system, several others have done it.
Should not be too tough to tune, shoot Johan an email when its done, maybe he can help you out.
Return to “General Support”
