05 avalanche 2500 8.1---"vehicle not in database"
ckeene
Post by ckeene »
u7193
newest version...
05, chevy, avalanche 2500, 8.1
cal_id am12592618cga
when i go to change paramenters is pops up vehicle not in database...need to download at dealer.
also...."out of memory"???
bought from summit racing, this week.
need anymore info. just ask.
thanks
christopher keene
RE: 05 avalanche 2500 8.1---"vehicle not in database&qu
Can you post the backup file here?
ckeene
RE: 05 avalanche 2500 8.1---"vehicle not in database&am
Post by ckeene »
will try to later...still learning about uploading/downloading
thanks for the quick reply!!!
keene
ckeene
Post by ckeene »
downloader cannot find tool...
how can i upload?
USB cable driver installed?
ckeene
Post by ckeene »
yup
check your cable settings in the Windows Device Manager for that usb cable...
get into the Windows Device Manager, and check the properties for that usb cable...
make sure the Com Port is set to 1, 2, 3, or 4... and that the Baud Rate is set to 115,200...
Orngasm
Post by Orngasm »
Great... I'm getting ready to install mine tomorrow. Bought mine form Summit this week also. Same vehicle; 05 Avalanche 2500 w/ 8.1. We'll see.
Robert
ckeene
Post by ckeene »
having same problem with tool for my 02 hd 8.1 i bought at same time...am i installing wrong?
Solid
Post by Solid »
Hello ckeene,
Did you download the DS downloader for the newer revison 9 or did you download the program for the older revisions? you can download it from the download page. Then if your predator doesn't connect automatic You have to adjust the com port into 1,2,3 or 4 and the baute rate the same as the software and in the menu of the predator as 06MonteSS said.
Good luck with the downloading!
And mike how can he upload the backup file? i thought that the predator should connect to the car first in order to make a back up file? or does he has to post up the CAl ID codes?
Greetings Solid
ckeene
Post by ckeene »
well i got the tool for my 02 8.1 to work...after i went to the the dealer and paid $75 dollars to reflash it still did not work!!! so... i told the tool it was a auto and not a stick(which it is)thanks to the tech who told me to try it!!!. the truck is freaking awsome now!!!. mpg went to crap cause i cant keep my foot out of it. nothing like a 8.1 and a stick. and thats after i went to a 34" tire.
now if i could get some help with my 05 avalanche 8.1 tool. i sent the file in to have them look at it and no reply in over a month now. HELP PLEASE!!!
keene
The 05 should be done soon, glad you got the 02 working.
May not be a bad idea to try this same trick with the 05 as well...
ckeene
Post by ckeene »
i tried it on the 05 and did not work. its an lazy butt auto(wifes truck...wont let me put a stick in it). please hurry, my wife has been on my butt about it. kinda sucks having a $400 piece of plastic sitting on top of the fridge and i have been off from work for over a month and had time to play with the truck. well back to playing int my shop.
thanks keene
ckeene
Post by ckeene »
any update???
keene
Solid
Post by Solid »
Not that i know off i'm still waiting to :(
