too much boost
Posted: Sun May 31, 2009 1:31 pm
by Neonsrt4ever
hi , i have a nsrt4 2004 stage 2 no cat borla exhaust. i can't have decent boost even a -35% in every range . i look at my log and sensed map is at 40 psi !! why. revision 9r17 u7134.
RE: too much boost
Posted: Sun May 31, 2009 7:59 pm
by NickLovin
Your boost pressure is 26 PSI not 40 PSI...
What wastegate actuator are you running?
Posted: Sun May 31, 2009 8:27 pm
by Neonsrt4ever
stage 2 wastegate all solenoid connected except for the surge valve . I have a hks bov
Posted: Sun May 31, 2009 8:32 pm
by Neonsrt4ever
i'm new in that. how do get 26 psi from my log . calc map- baro= 26 ?
Posted: Mon Jun 01, 2009 12:58 pm
by NickLovin
Neonsrt4ever wrote:i'm new in that. how do get 26 psi from my log . calc map- baro= 26 ?
You've got the right idea. To calculate boost you subtract the barometric pressure from your MAP pressure and convert it from KPa to PSI. If you do this with your log above using the maximum MAP pressure logged you get approximately 26 PSI.
Just FYI, AVG_MAP_TO_USE is usually the PID most people use for logging manifold pressure. It will generally read the same value are CALC_MAP however the averaged value seems to be a bit smoother and more consistent.
As far as your boost level goes, do you have toys by any chance? If so, what DAB position are you using?
Posted: Mon Jun 01, 2009 5:48 pm
by Neonsrt4ever
yes i have turbo toys , dab 3 , never try dab 2 or 1 with predator
Posted: Mon Jun 01, 2009 7:38 pm
by NickLovin
Neonsrt4ever wrote:yes i have turbo toys , dab 3 , never try dab 2 or 1 with predator
Try dropping to DAB 1 or 2 and seeing if the Predator is able to control boost at that point. That would be the first I'd try...
Posted: Thu Jun 04, 2009 7:50 pm
by Neonsrt4ever
i just try the dab in position 0 , 7 to 10 psi until i get 5100 5300 rpm the boost hit 20 psi . Is it normal with the 93 octane tune ?
