timing
RE: timing
the timing adjustment is only for WOT...
you'll need to log for KR... if there is any, then you'll need to back-off the timing...
RE: timing
so i need to adjust it and then log. do u know what the timing should be for max performance
RE: timing
4% is roughly equal to 1* of timing...
which tune are you using, and what octane gas??
and to be honest with ya, I don't ever increase the timing on their diablo tunes... it's already pretty maxed out as is in the canned tunes... when I do custom tunes for people, I actually end up pulling out some timing to cure minor KR issues they have, and they end up getting more power due to no KR and no timing being pulled by the ecm...
RE: timing
im using the diablo tune with 93 octane gas, i went to the track and lowered my time by a half a sec off the diablo tune by increasing my timing 6*, i think its degrees, but i ran out of time and didnt get to see how far i could push it
RE: timing
AAAAAAAAANNNNNNNNDDDDDDDDDDD................................BOOM!!!!!
Makin friends one post at a time!
05 Chevy Z71 5.3L, 18x9 KMC XD Spy Wheels, 275/70R18 Cooper Zeon LTZ, Cherry Bomb Exhaust, K&N Drop in, Predator TWEAKED
RE: timing
it runs 28* at wot with no knock, is that bad
- AKAssasain
RE: timing
mine is at 41* no knock, even if i lug.
RE: timing
yes, correct... that's at normal part-throttle driving...
it's not that high at WOT though, heh...
RE: timing
WOT vs part throttle timing are totally different worlds.
RE: timing
how much timing should they have at wot. a 350 small block is 32-36
