Can't read LIVE data through PC
duster360
Post by duster360 »
Trinity: 1r03.crom
U7134-(2003 SRT-4)
Dataviewer 3.2.0.2
When I Hit "Record" or "Connect" the small "connecting to vehical" progress window pops up and eventually I get the giant yellow "!" can't connect
I can connect to the Trinity fine throught the PC(DS downloader working good)
The Trinity can Flash my PCM without issue.
I can Download a save Log from the Trinity.
I can hit the "lightening bolt" and can Select any PID I want from the generated list.---The PIDs ONLY come up if I first download a saved Log. If I just try to click the lighten bolt without attemping to download a log, I get no connection.
RE: Can
We're on it...
duster360
Post by duster360 »
I think it might be more of a Trinity issue than with the data viewer.
I just tried to datalog just with the trinity and as soon as I hit record i would switch back to the previous screen. Anytime after that would happen I could "monitor" the PCM at all until I turned the car off/on.
Up until the time i want to actually record through "datalog", the Trinity diplays PIDs without issue through the "monitor" feature.
duster360
Post by duster360 »
Well gizmodo was kind enough to host the the new crom(1t04c) of his FTP site.
I updated this morning and I tired datalogging 1 PID(rpm) internally. It WORKED!!
I'm going to try to logg with the PC next.
If that works, I'll start adding PID until I can get it to fail
Needless Torque Calibrations
www.needlesstorque.com
duster360
Post by duster360 »
Well there's still issues. I thought the new crom might help bit, but no.
Logging more than a couple PIDs still locks up the Trinity.
"Monitoring" through the Trinity is also becoming less reliable.
I still need to see if I can datalog through the PC.
duster360 wrote:Well there's still issues. I thought the new crom might help bit, but no.
We have not been able to reproduce this on the bench, I may need to get a car in here, but only one I seem to have access to is Matts, and his logging has been working fine??
duster360
Post by duster360 »
mikel wrote: We have not been able to reproduce this on the bench, I may need to get a car in here, but only one I seem to have access to is Matts, and his logging has been working fine??
Matt's user name is sfla_srt4 , right??
Yes sir.
duster360
Post by duster360 »
Well even after a new Trinity Crom, PC datalogging is still broken.
Internal logging works so i don't think it'll take too much to fix the PC side
Are you still using 3.2.0.2??
3.2.0.4 is current, and we are testing 3.2.0.7 currently, should be released soon.
I will post it in the BETA section right now, please give it a try, as this should be fixed.
Mike
gizmodo
Post by gizmodo »
Can you please update the version numbers in the programs? I downloaded the latest version from the support site, but after installing it gives a different version number when going to Help > About. I think that causes a lot of confusion when trying to figure out what version everyone is running.
duster360
Post by duster360 »
Im using 3.2.0.4 although it says its 3.2.0.2 as gizmodo mentioned.
I downloaded the 0.7, I'll try it out and report back tonight
Return to “DataViewer/DV2”
