05 ram with Procharger
yellowhemi22
When I download the Stock tune to diablo tuner I have to sent it to Procharger so they can tune it.when the stock tune is downloaded to the tuner do I have download a diablo tune or can l leave it as it is, but if I leave is as is can it still be drove.if it can't be drove what diablo tune should I go with.
RE: 05 ram with Procharger
holy run on question Batman...
You can let the tool read a backup without installing a tune if you'd like, just unplug it when the tool says 'install tune/Modify tune'.
It can be driven like this, still stock, or you can load a tune if you like.
errr, umm, is there potential miscommunication here? and a chance of resultant fail?
(maybe I'm wrong. it just made me nervous)
The car will still have the stock tune in it and will run. SHOULD you drive the car with a procharger and stock tune may have a different answer.but if I leave is as is can it still be drove.if it can't be drove what diablo tune should I go with.
Pay attention... Mike said "still stock". You can drive the car like that and it will still have the stock tune in it. I don't think (just guessing) Mike was saying it's fine to drive it that way with the procharger? Like you probably wouldn't want to go into boost.It can be driven like this, still stock, or you can load a tune if you like.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
yellowhemi22
it has the unichip with the injectors behind the throttle body.it's the kit that Procharger had until now.I'm just upgradine to the bigger injectors and a custom tune for Procharger.i have to send Procharger a copy of the stock tune.
Yellowhemi:
I have the older style Porcharger setup too and want to upgrade, but Procharger told me I cannnot get the tune from them at all. Who did you talk to at Procharger to get the tune, or is there a way you could send me the tune? Where did you get your injectors? Thanks a ton man!
2006 Dodge Ram 5.7 Hemi
Predator
V.9r11
Custom tune from Procharger
Predator
V.9r11
