srt-4 rev limiter in neutral not working?
roniwan
Post by roniwan »
tried to adjust my rev limiter in neutral to 3300 rpmswith no luck why is this?
rev limiter in drive seems to work fine
gizmodo
RE: srt-4 rev limiter in neutral not working?
Post by gizmodo »
That isn't something you can set for the SRT-4. The PCM doesn't know when the car is in neutral.
roniwan
Post by roniwan »
well I just imagined that if the car its 0 mph it will asumes its in neutral and the neutral rev limit will be activaded so you can use it as a 2-step
duster360
Re: RE: srt-4 rev limiter in neutral not working?
Post by duster360 »
roniwan wrote:well I just imagined that if the car its 0 mph it will asumes its in neutral and the neutral rev limit will be activaded so you can use it as a 2-step
Nope, it doesn't work
04eblue
RE: Re: RE: srt-4 rev limiter in neutral not working?
Post by 04eblue »
That would be something usefull though if it could be done.
