New Cable is no help!!!!!
General Trinity Support
RAAEEEVO
Post by RAAEEEVO »
I received the "new & improved" cable today. It does the same thing, only locks on one side. So I trim about 1/16 off the end, now it clips but monitoring still locks up! pulls codes (none) fine, shows tune fine... but locks up on any dashboard screen, and only shows values on one guage. Is there a fix for this or can I get an RMA? I spent entirely too much money to own a product that is not operable, even after the "cable fix".
RAAEEEVO
RE: New Cable is no help!!!!!
Post by RAAEEEVO »
Can you tell me what revision is on the Trinity?
I have tested it in many 6.0 trucks and never seen the monitoring screen lock up as you describe.
Does the 0-60 or 1/4 mile timer work?
Does it flash the truck OK?
RAAEEEVO
Post by RAAEEEVO »
REV. 1r03
Does not flash because you dont offer current crom for my cal id: VXCF7CZI
Havn't tried the 0-60 or the 1/4 because nothing else worked.
2005 Harley Davidson 6.0 F350
Understood.
Which monitoring layout(s) have you tried?
RAAEEEVO
Post by RAAEEEVO »
I have tried all... as follows...
# 1 - Screen comes up, only VGT has a value - FREEZES - nothing works incl. back, exit etc. must unhook to restart
#2 - No screen - FREEZES - nothing works incl. back, exit etc. must unhook to restart
#3 - No screen - FREEZES - nothing works incl. back, exit etc. must unhook to restart
#4 - No screen - FREEZES - nothing works incl. back, exit etc. must unhook to restart
RAAEEEVO
Post by RAAEEEVO »
Any ideas?
New update sent to add support for your calid.
RAAEEEVO
Post by RAAEEEVO »
sent? i dont see it on the site. or am i missing something? sorry
where did my post go?
trinity-1t04c.zip
(23.98 MiB) Downloaded 364 times
RAAEEEVO
Post by RAAEEEVO »
lol .... Thanks I will give it a shot tonight...
RAAEEEVO
Post by RAAEEEVO »
Mike!, Mike!, we are making progress!!!!! After installing the test tune, monitoring works perfectly, 0-60 and 1/4 mile monitor fine. I will drive tomorrow to see tune performance and fill you in... However, I cant find a screen to customize guages or shift points (as shown on the trinity page) Is that something that isnt available yet, or not for diesels?? Any how, I know I've been a PITA! but for what its worth THANKS! Now I almost feel like I can brag about your product.
gizmodo
Post by gizmodo »
The way you adjust the gauges is to go into logging, and select the gauge setup you want, and then tap the gauge you would like to change. If you are talking about the shift light, use the same steps and tap the rpm gauge.
RAAEEEVO wrote:Mike!, Mike!, we are making progress!!!!! After installing the test tune, monitoring works perfectly, 0-60 and 1/4 mile monitor fine. I will drive tomorrow to see tune performance and fill you in... However, I cant find a screen to customize guages or shift points (as shown on the trinity page) Is that something that isnt available yet, or not for diesels?? Any how, I know I've been a PITA! but for what its worth THANKS! Now I almost feel like I can brag about your product.
VERY glad to hear this.
Let me know if you need anything else.
gizmodo wrote:The way you adjust the gauges is to go into logging, and select the gauge setup you want, and then tap the gauge you would like to change. If you are talking about the shift light, use the same steps and tap the rpm gauge.
Thanks Man!
Return to “General Trinity”
