Page 1 of 2
Shift kit for 4L60E
Posted: Mon Jul 06, 2009 8:33 pm
by emilbrath
2000 Silverado
Well, in short order with the canned tune installed from the Predator (U7198 v.9r15) and adjustments made to shift firmness and time while keeping the one tm feature "on" it's apparent that the weak link in the equation is the tranny. 2-3 and 3-4 are great, quick and firm, but there's a good deal of "sponge" in the 1-2 shift and I fear putting down any rubber is beyond what I currently have; Vararam intake, BBK 1&3/4 Shorties and Gibson Supertruck exhaust. Truck bogs at WOT from a standing start. Will a shift kit, say from TCI, help rectify the shortcomings and increase durability of the 4L60? What effect would a shift kit have on the diablo settings? What other mods would you suggest in my quest to take 10,000 miles of wear off my tires in 20 feet? Waiting on computer serial cable to load logs and custom tune and will be back with numbers when I get them.
RE: Shift kit for 4L60E
Posted: Mon Jul 06, 2009 10:59 pm
by 08Silverado
You could try a corvette servo, helps out with the 1-2 shift. I did it to my truck and it was a nice improvement over stock. Plus they only cost between 15-20 bucks,and, only takes about a half hour to put in.
Posted: Wed Jul 08, 2009 9:18 pm
by emilbrath
Picking up servo tomorrow. Any recommendations as to predator settings for shift parameters?
Posted: Wed Jul 08, 2009 11:08 pm
by 08Silverado
If I had TCM support I probly would.
Posted: Mon Jul 13, 2009 6:31 pm
by emilbrath
Thanks for the servo tip '08. WOW, lotta bang for the buck!
Posted: Mon Jul 13, 2009 8:26 pm
by Scooter88
hey emilbrath jus checking out this post..I have 04 GMC Sierra 2wd with 5.3l and was wondering how hard the servo was to put in and what it took? Definely helped huh? Part number by chance?
Posted: Mon Jul 13, 2009 11:07 pm
by 08Silverado
No prob man, I help when I can.
Posted: Wed Jul 15, 2009 6:48 pm
by emilbrath
Just because it was first time and I was extremely careful it took about an hour and a half. I have a 2000 Z-71 and after removing the heat shield I found there wasn't enough space to pull the servo out as a unit. I had to remove the pistons individually, then take the shaft out. The same was true of the install, spring and washers on shaft first, then placing the shaft into the servo housing, then slipping the pistons, washers and e-clip on with the shaft in the bore. Beware the "e" clip removal and installation and the snap ring!!! A standard wunderbar was perfect for leveraging the servo cover into place to install the retaining ring. I got a billet servo aftermarket, but the GM part for my truck would have been from a '99 or 2000 'vette
Posted: Wed Jul 15, 2009 11:07 pm
by Dschev1
Here is a site that might answer some questions to this topic, I installed the servo in my truck and found that it made a world of difference.
http://www.gmfullsize.com/forum/showthr ... vo+install
There are two kits available one for 1-2 and another that has different pistons for 1-2 & 2-3 I believe. I only installed the one for 1-2 .
Posted: Thu Jul 16, 2009 11:42 am
by Scooter88
Thanks for the info!
Posted: Fri Jul 17, 2009 11:17 am
by WhiteBuffalo
Ya, I did the servo...it adds a little grabbing power...but the 4L60E is still pretty weak.
I've been thinking about this!
http://www.finishlinetrans.com/transmissions/index.htm
WB
Posted: Tue Jul 21, 2009 2:56 pm
by SandMan817
just read that thread and i was wondering if putting in the vette servo will eliminate that "sponginess" feeling you get when shifting from 1-2 at WOT. if my truck 1-2 shift didnt have this problem im sure i would be getting much faster 0-60 times
Posted: Wed Jul 22, 2009 12:13 pm
by Dschev1
Yes it will improve the shifting from 1-2.
It'll hold better and shift quite abit firmer..
Posted: Wed Jul 22, 2009 4:32 pm
by emilbrath
Not to point out the obvious...but I will
!! For anyone doing the servo swap...I checked out a number of sites related to the swap and one of the common threads is hasty installations without proper lubrication of the "O" rings. Lotta torn ones out there and subsequent excedrin headaches. Make sure ya use a sufficient amount of assembly lube to do the job. Don't just use trans fluid as a number of folks have tried or recommended. And if it don't go...don't force it!
Posted: Mon Aug 03, 2009 11:23 pm
by chevyZ71
I have an 04 Z71 5.3 what to know want trans I have and where can i get a vette servo. thanks
