I have put a set of 100+hp injectors in my 7.3, they are single shot instead of split shot, can you guys build a custom tume or not for these injectors, it has a bizzar idle.
Thanks,
Brent
7170 and 100+hp injector problems, custom tune?????
- strokethis
Its not what you buy, it what you build.
predator programmer,adjustable HPOP module, Overboost eliminator, intake, 5 inch exhaust, banks wheel, built trans, manual lockup switch, 315's and 100hp sticks. 400hp and 900ft lbs to the ground.
RE: 7170 and 100+hp injector problems, custom tune?????
Custom tuning may be required to dial them in, but we dont currently offer custom tuning for diesels.
Unfortunately I don't have the older 7.3 files that used the single shot injectors available. If i did i would have been more then happy to at least get you started in the right direction. Let me look into it alittle further and see If i can come up with anything. Would you mind emailing me your original backup?
Don
2002 WS6
2002 WS6
