Will you ever make predator for the 2.7 Dodge Magnums
Magnum74
Post by Magnum74 »
Will you ever make predator for the 2.7 Dodge Magnums ? There are alot of 2.7s out there. It would be nice to have one have available.
RE: Will you ever make predator for the 2.7 Dodge Magnums
It is not likely.
Magnum74
Post by Magnum74 »
So there is nothing out there for these engines. At time of purchasing this vehicle. I didn't know about the engine size and which engine had the more horse power. The 3.5L dodge magnum predator cannot be changed to work a 2.7 engine ?
Nah different computer.
I'm not sure how many consumer cars were made with the 2.7. I know in the earlier years it was just a rental motor with the garbage 4 speed. I guess in the later years it bacame available to the public, but obviously not for performance.
Quick
Post by Quick »
They put a 2.7 in a 4500 lb car?
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
SamoanTsunami
Re: RE: Will you ever make predator for the 2.7 Dodge Magnum
Post by SamoanTsunami »
Quick wrote:They put a 2.7 in a 4500 lb car?
maybe the magnum is heavier, but on the charger, the weight on the sticker says 3817 for mine. 4500lbs cars are pretty much the SRT versions with all the extra stuff.
with the gearing and intake dual runner setup, the 2.7 does fine.
