Has anyone used the Predator tuner with an Edge EZ box? I already have the Edge but it's a pain to change the power levels unscrewing the cover and changing jumpers and I would like more power. I would set the Edge in the tow setting and leave it there and use the Predator to get the extra power when I am not towing.
I would assume I would just install one of the stack tunes and it should work as the puck and the Edge work in a similar function.
But I could be wrong.
Predator use with Edge EZ
Dodgezilla
RE: Predator use with Edge EZ
I'm sure it will work fine. Plus you get the added feature of the Boost Fooling from the EZ.. Keep the EZ on level 2 or 3....
04 Ram 2500 RARE Timberline Green 4x4 305/555 CTD/Stock48RE,DS Predator,VA C3.2,HE351 turbo, 2nd gen intake, BHAF,Custom 4" exhaust, More stuff....
That would be great since I already have the EZ.
